HeeheeBros's avatar
HeeheeBros
GS724T v4 Memory err log interpretation
Dear sir.
I am a system integration engineer in South Korea.
As I am checking switches, I found something abnormal.
My client uses Netgear Smart switch, GS724Tv4, so I request to experts here to figure out some error logs.
Is there anyone who can interpret this error log?
<11> Feb 27 12:28:44 192.168.201.29-1 DRIVER[57408828]: broad_hpc_drv.c(4362) 103707355 %% _soc_mem_array_sbusdma_read: EGR_PERQ_XMT_COUNTERS.epipe0 failed(NAK)
I wish to anyone can help me!
Due to I am Korean I am not good at English, please understand my grammatical errors. lol
  • schumaku's avatar
    schumaku
    Did the error only occur once or is it a recurring issue? It potentially is a memory problem on the switch affected..
    In case it's recurring, that switch needs to be replaced. Assuming the switch is still under warranty, head to https://my.netgear.com where your switch is registered, probably on your organization business account. Click on the device listed, and follow the [Request Hardware Support] process.
    No worries, I wish my Korean would be as good as your English. Welcome to the Netgear Community!
    • HeeheeBros's avatar
      HeeheeBros
      Thank you for your precious answer.
      The error occurred so many times already, however it shows as if it works well.
      But I am wondering that if the error occurs due to memory problem, the system alarm priority must be high, isn't it?
      However as I wrote the past article, the log starts with "<11>", that is severity level 3 by the software manual.
      I read software manual, and I found the the severity level is classified as below.
      - Emergency(0) / Alert(1) / Critical(2) / Error(3) / Warning(4) / Notice(5) / Informal (6) / Debug(7)
      In my opinion, if it caused by memory problem, severity level should be 0 - 2, I think.
      Of course, I cannot explain logically why it should be 0 - 2, it is just by my thought.
      Anyway, I am going to suggest to replace the equipment, because it has been so long time since it has installed.
      Once again, Thank you for your kind reply.
ProSupport for Business
