pbrady
Sep 21, 2020Aspirant
GS724TS - Javascript Errors
AHi all, I have 3 switches configure in a stack. I've previously had no problems until one day when I tried to log in to manage the device, and navigated to Switching -> VLAN -> Advanced -> VLAN ...
- Sep 22, 2020
If on Windows, try IE! You might have to use the compatibility mode.
pbrady
Sep 22, 2020Aspirant
You know what schumaku I thought I had covered every base but you've done it! Thanks so much.
In the past I've been running older versions of Firefox (atm it's 37.0) to get access but even that has failed me lately, maybe I need an older version. Really appreciate your help!
schumaku
Sep 22, 2020Guru - Experienced User
Legacy business applications are the key reason IE11 with all it's backward compatibility modes is still a core app on Windows 10. 8-)
