longwood
Sep 12, 2013Aspirant
GS728TP: PoE Fault
Hello, We just purchased a GS728TP PoE Smart Switch. Unfortunately, when we plug in a new device that requires PoE, the switch has to be rebooted before it will recognise (and provide power to) ...
- Dec 19, 2014Hello,
I'm very happy to find a topic referring exactly the issue i faced.
I also received a replacement switch put problem was still the same (last firmware from the website, etc ...).
After hours of troubleshooting, i found out that it's related to the cascaded switch behind this one.
This GS728TP was connected on a GS724TP, and both are POE switches, i disabled the POE feature on both switches on the ports used to cascade them and no issues anymore.
I don't know if you had same setup but in my case it's now solved ! :)
Regards.
longwood
Mar 26, 2014Aspirant
Against my better judgement, L3 support insisted upon sending me (yet) another replacement switch. This time, it was already "flashed" with the latest firmware (6.0.1.14).
I'm happy to confirm that the switch is (so far) behaving itself, and I no longer need to reboot the switch to when pluggin in additional POE devices.
I'll provide a further update in a few weeks.
Stephen
Stephen
