vishparakala
Dec 22, 2017Aspirant
GSS116E + LAG + VLAN(s)
How do I go about adding a LAG to a VLAN or VLANs in the GSS116E. This seems straightforward in the GS108Tv2 but I don't see an option in the GSS116E.
- Dec 22, 2017Judging from the manual, I think you just need to put all of the member ports in the VLAN.
TheEther
Dec 22, 2017Guru
- XavierLLDec 23, 2017NETGEAR Employee Retired
Hi ,
On the Plus Switches you don´t configure the LAG VLANs on the VLAN Membership side,
You just need to make sure that all ports that belongs to the same LAG have the same VLAN configuration.
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
- vishparakalaJan 03, 2018Aspirant
Thanks All.
That worked perfectly well !
Regards
