Marc_442
Feb 23, 2017Aspirant
GSS116E Drops off of network every few days
I have a GSS116E that drops off of the network every few days, cycling the power once usually resolves the issue, but on occasion, i need to cycle the power a couple of times. At the time of the ...
- Feb 27, 2017
Hi Marc_442,
It's weird, there is something going with the switch. I'd try another factory reset, but if it will still display the same issue please go ahead and contact our support team.
Thanks,
Marc_442
Feb 25, 2017Aspirant
Hi John,
The devices do NOT lose their IP address, if I disonnect any one of them from the switch and connect directly to my router, they immediately start responding to pings.
The lights apear normal, but any disconnected port does not change the light status (in other words the link light remains on even after disconnecting from the switch)
JohnRo
Feb 27, 2017NETGEAR Employee Retired
Hi Marc_442,
Thanks,
