GDRitter's avatar
GDRitter
How to use VLANs setup on SRX5308 based on ports used on GSS108E
I am not a networking guru so hoping for some direction. I think I know that this should work but I could totally be wrong as well.   We have a NetGear SRX5308 firewall that all our traffic goes th...
  • GDRitter's avatar
    GDRitter
    Dec 20, 2017
    OK,
    I decided if it isn't working, I might as well just start messing with settings and seeing if I stumble across anything. And I did.
    Instead of port based VLAN on the switch (GSS108E), I had to enable Advanced 802.1Q VLAN settings. Then I put port 1 (which is the uplink to the firewall) into both VLANs on the switch and marked it for TAGGED traffic. Then the remaining ports I set to one VLAN or the other and set them for UNTAGGED traffic. And now it's working exactly right.
    So now port 1 connects the whole switch to the firewall. Ports 2,3,4 give access to VLAN 1 only. Ports 5,6,7,8 give access to VLAN 2 only.
    This is great! Pics below of the working config. Still wired as shown in my previous post.
ProSupport for Business
