Tayyan
Oct 11, 2017Aspirant
Is it possible to restore switches configurations from a switch to another switch
Hello, My question ist it possible to restore switches configurations from a switch to another switch with a diffrent model ? as example i use switch: GS752TP can i restore its settings to anot...
- Oct 15, 2017
As I have mentioned previously, you cannot restore a config file to a different switch model. Hope these scenarios below would help you understand:
a. Restore config file from the NETGEAR GS752TP switch to another NETGEAR GS752TP switch - RECOMMENDED
b. Restore config file from NETGEAR M4100-26G switch (or any different NETGEAR switch model) to the NETGEAR GS752TP switch - NOT Recommended
c. Restore config file from NETGEAR GS752TP switch to NETGEAR M4100-26G switch (or any different NETGEAR switch model) - NOT Recommended
d. Restore config file of any 3rd party switch model (such as Cisco, Juniper, etc) to the NETGEAR GS752TP switch - NOT Recommended
e. Restore config file of the NETGEAR GS752TP switch to any any 3rd party switch model (such as Cisco, Juniper, etc) - NOT Recommended
DaneA
NETGEAR Community Team
Tayyan
Oct 13, 2017Aspirant
Thanks you DaneA, so we can only restore the config in GS752TP to another switch with the same model, but in general can we restore the configration from a modren switch model to another different switch, in other word is rule that both model and software should be the same in order to make a successful resotor without issues?
Tariq Tayyan
DaneA
Oct 15, 2017NETGEAR Employee Retired
DaneA
