andyadd
Dec 07, 2022Aspirant
JGS516PE not working after firmware upgrade
After upgrading the firmware to 2.6.0.48, my JGS516PE is not working properly. I am unable to access the web interface. I have done multiple factory resets. I have tried to connect with switch...
michaelkenward
Dec 08, 2022Guru - Experienced User
The JGS516PE is a switch. This place is all about routers.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Discuss Ethernet Switches Plus and Pro Managed
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- andyaddDec 08, 2022Aspirant
Thanks I realised that this was the wrong forum but couldn't figure out how to edit the post.
