bubbagump210
Nov 28, 2022Aspirant
JGS524PE switch loses VLAN config on reboot
As the title says, I have a JGS524PE that loses it's VLAN configuration for a specific VLAN on a specific port on a reboot. I am running firmware 2.6.0.48. All other VLAN configs work perfectly fine....
schumaku
Nov 28, 2022Guru - Experienced User
Just curious: In 802.1q, VLAN Membership, Advanced - if adding yet another random VLAN with some ports marked as Tagged, does the issue remain on the previous config?
- bubbagump210Nov 28, 2022Aspirant
I just added VLAN 123 with various ports added as tagged ports. I rebooted and all settings remained EXCEPT for VLAN 50 on port 6.
Before reboot:
After reboot:
- bubbagump210Dec 06, 2022AspirantAs a next step, I deleted VLAN 50 and recreated it as before. The same behavior returned on port 6.
