Ihaitspolling's avatar
Nov 16, 2016
JGS525PE All Amber LED on
Sturggling with a switch, we had a power outage and the switch cam back on with all amber LEDS on and no access to the web interface.   I have tried using the factory defaults button (held for eter...
  • DaneA's avatar
    DaneA
    Nov 16, 2016
    Hi Ihaitspolling,
    Since its still the same problem, it seems that the switch hardware became faulty.   I encourage you to open an online case with NETGEAR Support at anytime.  State what happened to your JGS524PE switch and the troubleshooting steps you did to isolate the problem.  Kindly attach the Proof of Purchase or Sales Invoice of the JGS524PE switch on the online case for warranty verification.  If ever the hardware warranty is still valid, then an online replacement will follow.
    DaneA
    NETGEAR Community Team
ProSupport for Business
