britesc
Oct 28, 2017Aspirant
LAG setup JGS524Ev2 and GS752TS kills network
Hi, I am attempting to create a 2 Wire LAG between a JGS524Ev2 and a GS752TS I am using ports 1 and 2 on each switch. I have created a LAG group for ports 1 and 2 on each switch. The JGS524Ev2 i...
- Oct 31, 2017
Hi DaneA,
Thanks for the reply.
I am now in the process of tring it out.....
GS752TS B5.2.0.2 ,5.3.0.31
JGS524Ev2 2.0.1.40
Will report back status ASAP
Thanks and kind regards,
jB :)
DaneA
Oct 30, 2017NETGEAR Employee Retired
Hi britesc,
Be reminded that the JGS524Ev2 switch only supports static LAG. On the GS752TS switch, a LAG interface can be either static or dynamic but not both.
Make sure that static LAG is set as the LAG type on the GS752TS. On the web-GUI, go to Switching > LAG > Basic > LAG Configuration then check the LAG type on ports 1 and 2.
Also, STP is not supported on the JGS524Ev2 switch. On the GS752TS switch, go to Switching > LAG > Basic > LAG Configuration then check if the STP Mode on ports 1 and 2 are disabled.
You may want to start from scratch by disconnecting all devices that are connected on both JGS524Ev2 and GS752TS switches. Then, configure static LAG then connect all devices to their designated ports on both JGS524Ev2 and GS752TS switches.
What is the current firmware version of the JGS524Ev2 switch as well as the GS752TS switch?
DaneA
NETGEAR Community Team
britesc
Oct 31, 2017Aspirant
Hi DaneA,
JGS524Ev2 2.0.1.40
jB :)
