acte28's avatar
acte28
Link Aggregation LAG with 40GB AOC breakout cable
I replaced 4 * 10GB ethernet cables to/from our core switch with an AOC breakout cable. From our core switch we are now connected with a 40GB QSFP+ AOC cable, and our office switch connected with 4 * 10GB SFP+
Since it's one cable turning into 4 separate connections, does LAG still need to be configured on either switch? It's working 'as-is' however I am not sure if speed or reliablity would be increased by configuring LAG.
Sorry if this is a basic question, networking is not my expertise, however thank you very much for your help!
  • schumaku's avatar
    schumaku
    At the end of the day it depends on what you want to achieve, what for these breakout connections are used for.
    Technically, e.g. on a 40G port with a break-out plugged and configured, the core switch will have four individual 10G interfaces instead of one 40G:
    core# show interface fec
    Name		Ifindex	Admin-fec 	Oper-fec    Status 	Speed 	Type
    Eth1/3/1	0x38014000	auto		auto	disabled	auto	QSFP-H40G-AOC3M
    Eth1/3/2	0x38015000	auto		auto	disabled	auto	QSFP-H40G-AOC3M
    Eth1/3/3	0x38016000	auto		auto	disabled	auto	QSFP-H40G-AOC3M
    Eth1/3/4	0x38017000	auto		auto	disabled	auto	QSFP-H40G-AOC3M
    These ports can be used to connect individual systems (needless to say, right ... think loop conditions et all), or if you intend to establish a LACP LAG it must be configured on both ends.
    • acte28's avatar
      acte28
      Thanks for the reply and for your help!
      The 40GB -> 4 * 10GB connection is only used to link our core switch to one of our office switches & using all four 10GB SFP+ ports. It's not going from our core switch to four separate devices.
      In this case, would there be any advantage of configuring LAG on both ends?
      • schumaku's avatar
        schumaku
        Yes, in my opinion we have to ... Otherwise you might end with a loop and port shutdowns.
