TomEcomm
Apr 04, 2023Aspirant
Loosing access to GS316EP Plus Switch after configuring, GS308's are OK
I have a Firewalla Purple firewall taking care of my connection to the internet and doing DHCP for 4 VLANS. The Firewall is connected to a GS316EP which is then connected to 2) GS308EP's. I have setu...
- Apr 06, 2023
OK, I think I got it figured out. The GS316EP has a setting for Management VLAN while the GS308EP does not. I had left this setting at VLAN 1 (Default). Changing this setting to VLAN 10 seems to have solved the issue. Now when I plug a PC into a port on any of the 3 switches that is configured for Untagged VLAN 10, I can reach any of the 3 switches as well as have internet access. I am not sure what the PVID on the Trunk Ports should be but I have them set at 10 as well and it seems to be working.
A bit curious but using the NSDT only ever shows the GS316EP, no matter which of the 3 switches I am plugged into. This is not an issue for me since the 3 switches are all configured with static IP's.
Thanks all for the input!
schumaku
Apr 04, 2023Guru - Experienced User
is "loosing the connection" limited to the reachability of the GS316EP LAN IP, or is there a systematic connectivity problem through the switches?
Reason asking? Lack of a managed core, and taking very simple micro-controller based design handing the IP based access, it's suggested (or required) to configure what makes up the management VLAN as an untagged network. The micro controller is not able to "see" the tagged administration traffic reliably.
