nathanr801
Mar 27, 2018Aspirant
Multiple Stack Links
From reading the "Multiple Stack Links" section of the S3300 User Manual, it sounds as though I can use two fiber connections to a 2nd switch to form a stack with 20GB bandwidth. I can also add two E...
- Mar 28, 2018
Wild guess from the road - don't we have to configure a LAG for each group of stack links?
DaneA
Apr 04, 2018NETGEAR Employee Retired
Hi nathanr801,
Welcome to the community! :)
Just to add and hope this might help. It might be possible that the ethernet ports used for stacking are still set as Ethernet. To check this, log-in to the S3300 web-GUI, then go to System > Stacking > Advanced > Stack-port Configuration. In the Configured Stack Mode field, set it to Stack then apply it. A manual reboot of the switch is required for the changes to take effect. As reference, kindly read pages 85-86 of the S3300 user manual here about Advanced Stack-Port Configuration.
DaneA
NETGEAR CommunityTeam
DaneA
Apr 10, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- nathanr801Apr 10, 2018Aspirant
I apologize for the delay. Because the switches are in production (using a single link) I have to schedule the downtime to test. I was hoping to do this last friday but was feeling under the weather so I wasn’t able to come in to perform the adjustment. I’m back to work now and am reviewing my calendar for a reschedule.
I sincerely appreciate the responses so far. The ports are both configured and running in stack mode so I am looking into the LAG suggestion. I hope to have results this week.
I'm preparing for the LAG test. If I understand the "Multiple Stack Links" section correctly, since the switches are currently connected with Fiber, I should be able to create a LAG with the Ethernet ports, connect the Ethernet cables, then disconnect the fiber link without down time.
While preparing the LAG, I ran into a question. Do I need an individual LAG on each speperate physical switch or can I add all four ports into a single LAG. As I link about this, it seems that each physical switch will need a LAG. Thoughts?
