falafell42's avatar
falafell42
netgear gs724t poe injector
I have a netgear gs724t and am trying to use poe injectors.
Whenever I use them on the switch every port negotiates down to 100mb regardless of what i set.
Do i need specific voltage injectors?
Does the switch support this?
Thanks
  • plemans's avatar
    are you going:
    router/data connection------>switch-------->poe injector------->device needing poe?
ProSupport for Business
