timlucky1
Mar 31, 2023Aspirant
Netgear JGS516PE Firmware 2.0.0.31 Upgrade
I have a switch in need of firmware upgrade currently 2.0.0.31 to 2.6.0.48 but, I can not login to GUI but, the discovery tool sees the device. I can use the prosafe plus utility 2.7.8 but, I can onl...
- Mar 31, 2023Typical reasons are different IP addresses from inconsistent IP subnetworks, and host security prohibiting tftp access.
With the known password, and assuming the same IP subnet, you can use a web browser instead. Much less hassle.
timlucky1
I have been able to get to the firmware update section but, now I am getting a "TFTP - Time Out". I have tried multiple times and I am plugged directly to the switch.
- schumakuMar 31, 2023Guru - Experienced UserTypical reasons are different IP addresses from inconsistent IP subnetworks, and host security prohibiting tftp access.
With the known password, and assuming the same IP subnet, you can use a web browser instead. Much less hassle.- timlucky1Apr 01, 2023AspirantThanks for your input I was able to get the firmware upgraded by using browser finally.
