timlucky1's avatar
timlucky1
Netgear JGS516PE Firmware 2.0.0.31 Upgrade
I have a switch in need of firmware upgrade currently 2.0.0.31 to 2.6.0.48 but, I can not login to GUI but, the discovery tool sees the device. I can use the prosafe plus utility 2.7.8 but, I can onl...
  • schumaku's avatar
    schumaku
    Mar 31, 2023
    Typical reasons are different IP addresses from inconsistent IP subnetworks, and host security prohibiting tftp access.
    With the known password, and assuming the same IP subnet, you can use a web browser instead. Much less hassle.
ProSupport for Business
