adakai's avatar
adakai
Netgear smart switch VLANS not working
So I just purchased a Netgear Smart Switch. The switch I bought: https://www.netgear.com/support/product/gs108Tv3.aspx
I have another dumb switch that it is connected to with a crossover cable. I want to use the smart switch and make a VLAN network for all my VM's on Proxmox.
I followed a YouTube video on setting up the VLAN's on a Netgear Switch:
https://www.youtube.com/watch?v=6G9-8tf1kuk
I went through and configured the Windows 11 laptop I have connected to it for test purpose with a static IP on the same subnet.
But for what ever reason I cannot ping beyond the Smart Switch. I can ping 192.168.69.254 (smart switch) but if I try to ping 1.1.1.1. it doesn't work?
I also went through the PDF user manual on setting up a VLAN and still with the same results? So not sure if I am missing something or what.
The future goal of this is to be able to have my Proxmox Management cable on my home network which is 192.168.0.0/24 but have all my VM's connected through a VLAN aware bridge of 192.168.69.0/24.
Any help or suggestions on this would be much appreciated.
  • schumaku's avatar
    schumaku
    Of course the VLANs work as expected: Each VLAN does make a dedicated network, leaving tiny details like STP and RSTP alone, each behaves like a unmanaged switch for each network.
    You need to look into the IPv4 routing, being on an additional fully fledged router, or limited to some extent on the switch itself.
    • adakai's avatar
      adakai
      so not sure if you read my post entirely, but I posted a video that I followed exactly so never did touch STP and RSTP.
    • adakai's avatar
      adakai
      What do you mean exactly by IP4 routing? Like is there a specific setting I should be looking for?
      • schumaku's avatar
        schumaku
        Show us the switch IP config and the VLAN Routing config.
        Does your Proxmox network config require a trunk port, so tagged?
        Also add the exact switch model and hardware version and the firmware in place.
        Shuddering a little bit reading about an unmanaged switch involved here - for what should be dedicated networks and dedicated IP subnetworks.
ProSupport for Business
