clarens2253's avatar
clarens2253
NMS300 1.7.0.1
Hi.
NMS300 1.7.0.1 + 3x GS748Tv5 FW: 6.3.1.36 + GS724Tv4 FW: 6.3.1.36. Backup of SW configuration not working, passwords are correct. I got errors:
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    clarens2253,
    On what Operating System is the NMS300 installed?
    Did you just newly update the NMS300 to v1.7.0.1?  If yes, is everything working fine before you did the update?
    DaneA
    NETGEAR Community Team
    • clarens2253's avatar
      clarens2253
      NMS 1.6.0.27 same situation. I think the problem is in firmware 6.3.1.36
    • DaneA's avatar
      DaneA
      clarens2253,
      Let's try this.  Kindly try to uninstall then reinstall the NMS300 in your PC.  Then, check if the same problem will occur.
      If ever the same problem occurred, I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
      DaneA
        clarens2253
        Windows 2012 R2 Foundation. Reinstallation didn't worked. Support contacted.
ProSupport for Business
