gfunkdave's avatar
gfunkdave
No Bootloader Upgrade Prompt on GS105Ev2?
I upgraded a GS105Ev2 to firmware version 1.5.0.5 from an older version (I forget which one) using TFTP. The update went fine, but the switch didn't prompt me to upgrade the bootloader. Another GS105...
  • JohnC_V's avatar
    JohnC_V
    Feb 14, 2018
    gfunkdave,
    Yes, you may try to downgrade the switch. Then try to put it back again to v1.5.0.5.
ProSupport for Business
