GF88's avatar
GF88
Only the GS308 series loses connection from the Wi-Fi router
When I connect a Sony Wi-Fi router(NSD-G1000T) to Port 1 of a GS308 series switch, it receives an IP address from the DHCP server and functions as a switch for the first 3-5 seconds.
My PC connected to Port 2 of the switch can send/receive ping both the switch and the Wi-Fi router.
However, after the first 3-5 seconds passed, the Wi-Fi router then disconnects from the switch. After the disconnection, my PC can ping only the switch. The Wi-Fi router is missing form PC side.
[Connection Map: Not work]
Sony Wi-Fi router with DHCP Server <-- Port 1--> GS308 Switch <-- Port 2 --> PC
But if I replace the GS308 switch with GS108E, it works well.
I have multiple GS308 and GS108E, I retry and test this by each device but the result was same.
It is not individual device issue, it seems to have some compatibility issue.
[Connection Map: Work]
Sony Wi-Fi router with DHCP Server <-- Port 1--> GS108E Switch <-- Port 2 --> PC
The GS308 seems to have some compatibility issues with Sony Wi-Fi routers.
If I could solve the problem by turning off some function of the GS308, I would be grateful.
I would appreciate some advice from anyone who has had a similar experience and has a solution.
  • GF88's avatar
    GF88
    Nov 18, 2025
    schumaku​
    >Ensure STP (RSTP) et all (like the Loop Prevention) are disabled, and try again.
    That (STP) setting (default: ON) was the cause of this issue!
    I didn't fully understand STP, so I couldn't fully utilize your comments.
    Thank you again for following up.
    I wanted VLAN functionality, but it seems I was buying a device beyond my level of knowledge. I need to learn more about the device I purchased (GS308T).
  • StephenB's avatar
    Are you connecting the 2.5 gbps port in the router to the switch?
    If so, have you tried connecting a gigabit port instead?
    • GF88's avatar
      GF88
      StephenB​
      I tried 1.0 gbps port instead of 2.5 gbps port, but the result was not improved.
      I also tried port speed mode 1.0 gbps instead of auto. But the result was same.
      Thank you for your comment.
      • StephenB's avatar
        Is anything else connected to the switch?  Or is it just the router and the PC?
        Does the PC work correctly when connected directly to the router LAN port?
  • schumaku's avatar
    schumaku
    A GS308 is an unmanaged switch, nothing to configure.
    Or are we facing any kind of GS308E, GS308EP, or GS308EPP?
    Unlikely with such a simple config, the Easy Smart Essentials Switches (PoE or not), but also the GS108E the OP is referring to, have a feature called LOOP DETECTION. If in doubt, disable this feature - especially if paired with some more sophisticated Mesh WiFi system, eg. used as a wireless access point.
    This has no impact on the switch at least.
    • StephenB's avatar
      It shouldn't, unless there is a compatibility issue in the router ethernet.  Perhaps not likely, but easy to test.
      The Sony router appears to be a stand-alone router, not a mesh.  Though I can't read Japanese, so I can't get much info from the manual...
    • GF88's avatar
      GF88
      schumaku​
      Thank you for your advice.
      I confirmed the setting of the GS308T.
      I had proceeded factory reset at the previous investigation procedures, and the confirmed setting: the loop protection setting was OFF.
      I also confirmed the settings of the Sony router, but I could not find sittings regarding these loop protection/detection functions.
      I am still having issues, but I appreciate your support.
      • schumaku's avatar
        schumaku
        GF88 wrote:
        ...setting of the GS308T.
        Again a totally different beast. That's why the community does always request the exact device make and model.
        These GS308T (might) have Spanning Tree Protocol (STP) enabled by default - as these are standard for business and enterprise class networking devices - something these kind of Easy Mesh and similar are simply highly incompatible (just like the Loop Prevention the GS308E does have) to these wonderful Mesh **** - albeit always calming it's IEEE compliant. All makers of these wonderful MEsh systems don't tell the uneducated customers that only so called "unmanaged" switches can be used - the reasons are Loop Prevention and even more STP.  These systems do -not- accept the same MAC address appearing on different switch ports or networks.
