IFGinn
Dec 17, 2021Follower
Optimising setup to maximise broadband speed
Hi, Just joined the community and hooe you all are keeping well! I was fortunate enough to install fibre to the home. I receive about 800MB downlink which is great, but the Netgear switc...
michaelkenward
Dec 18, 2021Guru - Experienced User
IFGinn wrote:
I receive about 800MB downlink which is great, but the Netgear switch now seems to be the bottleneck.
Is the JGS524Ev2 switch the only Netgear device on your network?
If so, you probably won't get much feedback in a section given over to talking about General WiFi Routers (Non-Nighthawk and Non-Orbi).
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
or maybe
Discuss Ethernet Switches Plus and Pro Managed
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
