IFGinn
Dec 17, 2021Follower
Optimising setup to maximise broadband speed
Hi, Just joined the community and hooe you all are keeping well! I was fortunate enough to install fibre to the home. I receive about 800MB downlink which is great, but the Netgear switc...
schumaku
Dec 29, 2021Guru - Experienced User
Q1: No. The swith has all Gigabit-capable ports. Check the NETGEAR 24‑Port Gigabit Smart Managed Plus Switch JGS524Ev2 Installation Guide for the link rate on the connection in question. Check the cable or wiring btween the router and the switch - typical reason for 100 Mb/s link rates are incomplete cables, bad pairing. A complete and healthy CAT5A or better netowrk cable with all four pairs correctly crimped is required - this allows GbE 1000 Mb/s
