itplustech
Nov 19, 2016Aspirant
port 25 on GS724Tv4 keeps shutting down
Hi
Need some help!
We have a fibre link between 2 offices.
Office 1 has a GS724Tv4 smart managed Switch and Office 2 has a JGS516 unmanaged switch with a fibre media converter.
since 2 days ago port 25 on the GS724Tv4 has been shutting down and Office 2 cannot connect to Office 1 over the fibre link.
I can enable the port but it soon shuts down again.
Having a look at the logs I see the following:-
DOT1S[61169596]: dot1s_txrx.c(225) 25002 %% dot1sBpduReceive(): Discarding the BPDU, cannot get buffer from buff pool
Spanning Tree Topology Change Initiated: 0, Interface: g25
DOT1S[55471756]: dot1s_control.c(1223) 239 %% Rate limit of 15 for 3 consectutive seconds has been exceeded on port g25
OT1S[55471756]: dot1s_ih.c(1646) 238 %% Diagnostically disabling interface g25
Let me know what you think this could be related to?
Thanks!
Apologies for the delay. Had to eventually go oniste.
Problem was that some champion decided to loop a cable into a small 5 port switch
Removed and problem solved
- DaneANETGEAR Employee Retired
Hi itplustech,
Welcome to the community! :)
Let us isolate the problem. There are 2 SFP ports on the GS724Tv4 switch which are ports 25 and 26. Kindly connect the fiber link to port 26 of the GS724Tv4 then observe if it will shutdown as well as if the same logs will still appear.
Kindly answer the questions below:
a. What is the current firmware version of the GS724Tv4 switch?
b. After you have connected the fiber link to port 26 of the GS724Tv4, did it shutdown?
c. Does same logs appeared after you have connected the fiber link to port 26 of the GS724Tv4?
I look forward to your response.
DaneA
NETGEAR Community Team
- itplustechAspirant
I'm glad that you were able to figure it out and resolved the problem. :)
Since the problem has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
