Bugner
Jul 07, 2016Aspirant
Problems connecting GS728TP to GS110TP using SFP fibre ports
Hi, I am new to networking and have set up a small home office in my garden connecting the house to the office with SFP Fibre betwween GS728TP (House) to a GS110TP (Office). Data seems to be runnin...
- Jul 11, 2016
Hi
Yes I finally got to the bottom of the problem. I had a Sonos Play 5 speaker connected to the GS110TP switch. It had previously been in the house and on a Sonos wifi mesh network. It was still connecting to the mesh network in the house as well as the new wired ethernet link creating a network loop.
I found a way to disable the wifi on the Sonos device which is now connected via Ethernet only and the problem has gone
All seems to be working well now. Thanks for checking back
Kind Regards, Andy
DaneA
Jul 11, 2016NETGEAR Employee Retired
Hi Bugner,
Just want to follow-up on this. Were you able to check each device in the office and know the cause of the problem?
DaneA
NETGEAR Community Team
Bugner
Jul 11, 2016Aspirant
Hi
Kind Regards, Andy
- DaneAJul 12, 2016NETGEAR Employee Retired
Hi Bugner,
I'm glad to know that you were able to identify the cause of the problem. :)
Since the problem has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
