clarkmtc
Nov 27, 2017Tutor
ProSafe Plus Downspeeding Ports on its own
Hi, I recently purchased the subject matter smart switch in the model info line. I love the switch and it compliments my Nighthawk router 9000 very well alongside a Synology 5 disk array. I love the ability to use link aggregation between the boxes, etc...I have run in to one snag, however that I cant seem to get past. I have fiber running to my building 500/500 (KT Telekom Korea) that tests through OOKLA to several sites at 500/500 from the modem clean and from the 9000. Several times I have even gotten 500/500 at the client level, which is what I should get (I am not using QOS / throttling), but the last week, ports are automatically decellerated / downsped to 100mb (exactly), every day, without having set it up. Workstations no longer get the full 500 up down, but peak at 100. If I throw my old Netgear "dumb" switch on the 9000, I get full 500/500 again to all clients. The switch is pretty much OOB / default setup, other than the LAG ports I use for the NAS, so not sure whats causing the downspeeding. I dont want that.
Ideas? What did I miss?
Mike in Korea
Factory reset, unfortunately, didn't change the downspeeding, in fact, it shed light on something else. Recently, I had purchased some very nive (so i thought) category 7, braided ethernet cables from Amazon, 1, 3 and 8 meters. I wanted to use the best cable possible for my main workstation, NAS, port aggregation between switch / NAS. What I found was, by chance, when I switched from the "high end" CAT7, braided cable, back to normal CAT5/6 at the PC or at the NAS, everything immediately shot back up from 90-100mb cap to 490-500mb, as it should be. Strangest thing I have ever seen. I did not think CAT7 cable would cause this and I tries several different lengths and pre-cut sizes, same 100mb cap. No idea why it does that, but it does. Perhaps some kind of pair mismatch with the internal house wiring / ports on the switch, etc....
So, these are the cables that slowed me down: Cat7 Ethernet Cable 3 ft, Cat 7 RJ45 LAN Network Cable High Speed Durable Nylon Braid STP with Gold Plated Plug (3FT/1M, Nylon Braid - Black)
Anyway, Im back up and flying @ 500mbps with standard CAT5. Who'd have thought.
Mike
- JohnC_VNETGEAR Employee Retired
Hi clarkmtc,
Welcome to our community!
We may need to have a little workaround here. You may upgrade the firmware to its latest version first and reset it to factory default. Then connect the switch without any configuration.
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
- clarkmtcTutor
Mike
