fiscap
Jul 24, 2021Aspirant
ProSafe Plus JGS516PE - All Amber LEDs
I have a ProSafe Plus JGS516PE switch which has been working great for the last couple of years, however this morning we had no network throughout the house. In checking the JGS516PE, I noticed that all ports (including ports without any cables connected) were lit amber. I power cycled the switch a few times and the issue persisted, so I attempted to use the 'Factory Defaults' switch several times, however the issue remains.
Please let me know if there are other troubleshooting steps I should try.
- DaneANETGEAR Employee Retired
Common symptom of failing power supply. If you cannot provide sales documentation or whatever else is needed in order to avail yourself of the free replacement lifetime warranty you might consider opening up the switch and looking at the large electrolytic capacitors on the power supply board, and if any of them are bulging/or split, replace ALL electrolytic capacitors on the supply board.
