toilatoi71312's avatar
Jun 07, 2017
Rate limit option in GS748Tv5 and MAC static DHCP
Hi dear,
I can't find the rate limit option in my GS748V5 same as here
http://documentation.netgear.com/gs108t/enu/202-10337-01/GS108T_UM-07-05.html
How I can  limit rate by each port.
And about DHCP static by port, I want a port will take only one IP and alow a device identity by MAC in list only.
What option can help me to do that?
Thank you.
  • Hi toilatoi71312,
    Welcome to the community! :)
    I will need to inquire your concern about Rate Limiting on the GS748Tv5 and I'll post here once I got a feedback.
    About you other concern, as I understand it, you want to allow a specific MAC Address to have connectivity to a specific port on the switch, am I right?  If ever I am right, kindly read about Port Security on pages 203-205 of the GS748Tv5 administration manual here.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi toilatoi71312,
    DaneA
    • Thank you dear,
      I have find security port config in your guid. Thankyou so much.
      As in administration  manual, seem not have option of ratelimit (by kbps/speed)
      Hope you can help me to config it.
      Thankyou
      • DaneA's avatar
        DaneA
        toilatoi71312,
        I inquired your concern about Rate Limiting on the GS748Tv5 to the higher tier of NETGEAR Support and just got a feedback today.  It was advised by the higher tier of NETGEAR Support to have Rate Limiting be logged as a feature request for the GS748Tv5.
        With regard to this, I suggest you to post your concern as feature request on the Idea Exchange for Business board here.  In this way, the development team can see what feature does GS748Tv5 users wanted to be added to the functionality of the switch.
        DaneA
ProSupport for Business
