Devc-In-Oz's avatar
Devc-In-Oz
Accessing 3 switches - wrong subnet
Hi all, I'm sure this will have been answered before but my searches are throewing up a blank.    I have 3 switches which I seem unable to access. 16 port (GS116Ev2), 5 port (GS305E), and another 5...
  • Devc-In-Oz's avatar
    Dec 30, 2025
    OK, in case anyone else is finding this - I think I have solved it. Here's what I did to get access:
    1. Factory reset each switch (hold the reset button in for 30 seconds);
    2. This placed them into receiving DHCP from the router and they were allocated an IP address on the same subnet as the router;
    3. Update the firmware (they were all using slightly old firmware) - but only do this using the ProSAFE Plus Config Utility after going into the web admin page and allowing prosafe to also manage the switch - do this as below...
    4. Go to the web interface of the switch 192.168.1.xxx and under 'switch management mode' allow prosafe to also manage your switch - apply and logout;
    5. Go back to Prosafe, refresh and highlight the switch and press apply. This opens up an admin tab and you can now go to the firmware and update it using the Prosafe untility.
    6. Once updated wait a little while and the switch will be discoverable by either prosafe or the network discovery tool (seems a bit random - my 5 port GS305E is now only discoverable by the discovery tool, but my 16 port GS116Ev2 is only discoverable with Prosafe);
    7. Crack a cold one and relax.
    Hope this helps someone.
ProSupport for Business
