hshah96's avatar
hshah96
Configuration of GS116 Switch
Hi   Before I start is is not the Pro SAFE Plus, Just the ProSafe.    I have connected it up to the home router and then set up my Sonos system. Once it was set up it was workig. Then it suddnely...
  • XavierLL's avatar
    XavierLL
    Dec 22, 2016
    Hi hshah96
    Sorry for the confusion but if the switch is the GS116 not the GS116E (Plus version) is an unmanaged switch so you can't manage it.
    What I recommend is to try to isolate the network, just plug the switch the router an to the computer and see if you can get internet. It's likely that some of the new devices will be acting as DHCP server and will break the internet connectivity.
    Hope that it helps.
    Xavier Lleixa
    NETGEAR CBU PLM
ProSupport for Business
