Pleasefix
Feb 05, 2026Aspirant
Netgear GS105Ev2 mismatch
Hello, Since the past couple of days, I encountered a problem where a number of applications and websites are not working properly. Sometimes they do, sometimes they don't. For example, on twitch...
Pleasefix
StephenB wrote:Do you see the same error if you connect one of these cables to another ethernet device?
I don't see the same error.
StephenB wrote:I am wondering if it might be the socket in the PC.
This is what I was wondering as well. As nothing has changed, hardware of software-wise) between it working properly (2 weeks ago) vs now.
That doesn't quite explain the same errors on the same applications/websites though. As those are quite consistent. Whereas other websites have no issue at all. For example, discord keeps working even though it's also live data with no buffer.
schumaku
Feb 05, 2026Guru - Experienced User
Pleasefix wrote:That doesn't quite explain the same errors on the same applications/websites though
Connecting your PC direct to the router LAN port does not show an issue?
Somehow, I suspect your switch requires a replacement.
Suggest heading to https://my.netgear.com) - select switch (assuming it's an almost new switch) and file a hardware exchange request.
- StephenBFeb 05, 2026Guru - Experienced User
Could be. The GS105E doesn't cost much, so a risk-buy is still a reasonable option, even if the switch isn't covered by warranty.
But the issue with port 3 might be the cable, so it would be useful to check that separately.
