GF88
Nov 17, 2025Aspirant
Only the GS308 series loses connection from the Wi-Fi router
When I connect a Sony Wi-Fi router(NSD-G1000T) to Port 1 of a GS308 series switch, it receives an IP address from the DHCP server and functions as a switch for the first 3-5 seconds.
My PC con...
- Nov 18, 2025
schumaku
>Ensure STP (RSTP) et all (like the Loop Prevention) are disabled, and try again.
That (STP) setting (default: ON) was the cause of this issue!
I didn't fully understand STP, so I couldn't fully utilize your comments.Thank you again for following up.
I wanted VLAN functionality, but it seems I was buying a device beyond my level of knowledge. I need to learn more about the device I purchased (GS308T).
schumaku
Nov 17, 2025Guru - Experienced User
A GS308 is an unmanaged switch, nothing to configure.
Or are we facing any kind of GS308E, GS308EP, or GS308EPP?
Unlikely with such a simple config, the Easy Smart Essentials Switches (PoE or not), but also the GS108E the OP is referring to, have a feature called LOOP DETECTION. If in doubt, disable this feature - especially if paired with some more sophisticated Mesh WiFi system, eg. used as a wireless access point.
StephenB wrote:Are you connecting the 2.5 gbps port in the router to the switch?
This has no impact on the switch at least.
- StephenBNov 17, 2025Guru - Experienced User
It shouldn't, unless there is a compatibility issue in the router ethernet. Perhaps not likely, but easy to test.
The Sony router appears to be a stand-alone router, not a mesh. Though I can't read Japanese, so I can't get much info from the manual...
- schumakuNov 17, 2025Guru - Experienced User
StephenB wrote:
The Sony router appears to be a stand-alone router, not a mesh. Though I can't read Japanese, so I can't get much info from the manual...Wrong. Work on your Japanese language please - it is an EasyMesh compatible system 8-)
Together with the Sony NSD-M1000 it can make-up a mesh system...
- GF88Nov 18, 2025Aspirant
schumaku
Thank you for your advice.I confirmed the setting of the GS308T.
I had proceeded factory reset at the previous investigation procedures, and the confirmed setting: the loop protection setting was OFF.I also confirmed the settings of the Sony router, but I could not find sittings regarding these loop protection/detection functions.
I am still having issues, but I appreciate your support.
- schumakuNov 18, 2025Guru - Experienced User
GF88 wrote:
...setting of the GS308T.
Again a totally different beast. That's why the community does always request the exact device make and model.
These GS308T (might) have Spanning Tree Protocol (STP) enabled by default - as these are standard for business and enterprise class networking devices - something these kind of Easy Mesh and similar are simply highly incompatible (just like the Loop Prevention the GS308E does have) to these wonderful Mesh **** - albeit always calming it's IEEE compliant. All makers of these wonderful MEsh systems don't tell the uneducated customers that only so called "unmanaged" switches can be used - the reasons are Loop Prevention and even more STP. These systems do -not- accept the same MAC address appearing on different switch ports or networks.
schumaku
