MikeEinhorn's avatar
MikeEinhorn
Setting up Switch for Remote Desktop
Hello,   I recently purchased a GS105E switch to replace an old wireless router I had.  On my older unit was straightforward to open ports to allow remote desktop to work but on the GS105E I don't ...
  • TheEther's avatar
    Mar 16, 2018
    A switch is not a router. A router, particularly in the home router segment, is commonly a firewall, NAT, Wi-Fi Access Point, IP router and switch. A switch alone is used to connect multiple Ethernet segments (cables) together. Because a switch has no firewall, it can no concept of opening ports.
    If you need a router, get a router.
ProSupport for Business
