Cerberusict's avatar
Jun 03, 2026
System name
Hallo   GS728TXPv3 with firmware: 6.2.2.40   This is a new switch and i just did the basic setup wenn i hung it in a DC. Besecly the old switch was still in use. Now that one is gone and i want...
  • schumaku's avatar
    Jun 03, 2026
    Cerberusict wrote:
    But i can not change the name or system contact.
    System Name, System Location, and System Contact can be configured in the Web UI under
    •  System -> Management -> System Information
    The System Name can always be configured, independent of the Insight Management mode.
    System Location, and System Contact fields are greyed in Insight mode. There is a radio button (on/off) control, to temporarely disable Insight mode on the
    • Dashboard in the Device Details
    All the other SNMP controls - for v1/v2 as well as for v3 - are under
    • System -> Protocols -> SNMP ...
ProSupport for Business
