bains1000
Jun 26, 2017Aspirant
VLAN Configuration Assistance
Hi I am trying to setup a failry simple VLAN configuration on the GS728TPP Switch and i'm struggling to understand how the Vlan works on here. I want Port 1 and 2 to be untagged on VLAN 10 I...
- Jun 26, 2017
Hi bains1000,
Welcome to NETGEAR community!
You can configure the switch with Port 1 and 2 to be untagged on VLAN 10, Port 3 and 4 to be untagged on VLAN 11.
The import point is that, you need to change port pvid, after creating new vlan 10 and vlan 11, you can add port1/2 to vlan 10’s members on VLAN membership page, then change port1/2 pvid as vlan 10 on Port pvid configuration page; add port 3/4 to vlan 11’s members, then change port 3/4 pvid as vlan 11. At this moment, port 1/2/3/4 should remove from the default vlan 1.
NETGEAR Employee
ElaineP
Jun 26, 2017NETGEAR Expert
Hi bains1000,
NETGEAR Employee
bains1000
Jun 27, 2017Aspirant
Thanks this looks like it has worked.
