fofwisdom
Dec 19, 2016Aspirant
XS708Ev2: packet drop over 1473
Recntly I was bought XS708Ev2. If the size of the packet exceeds 1473, communication is not possible. Currently fimware is v1.0.0.4. I was upgraded v1.0.0.3 to v1.0.0.4 I would like to tr...
- Retired_MemberDec 22, 2016
Hi fofwisdom,
Welcome to NETGEAR community, 1514 restriction is only for ICMP packet, for other normal network traffic, Jumbo packet size (default) is 9216, DUT will drop packet larger than 9216 size.
Let's know if you see different result in further testing.
ElaineP
Dec 19, 2016NETGEAR Expert
Hi fofwisdom,
Welcome to NETGEAR community!
The plus switch L2 jumbo frame is always enabled, and the maximum frame size up to 9216 bytes.
About the size of the packet exceeds 1473, how do you check it? What the packet is? And can you send me the network topology? Look forward your reply, thanks.
The firmware you can get only is from the support page of Netgear.
NETGEAR Employee
fofwisdom
Through all packets draw. Trunk and inside traffic all of them.
- [S1] 192.168.144.251 = XS708Ev2 v1.0.0.4
- [S2] 192.168.144.252 = GS724Tv3 v5.4.2.25
- ElainePDec 20, 2016NETGEAR Expert
Hi fofwisdom,
- For XS708Ev2, Switch support to reply an ICMP Echo request (PING) that is in any size smaller than 1514 bytes.
According it, I ping my XS708Ev2 :192.168.1.32, and the size is 1472, the length is 1514, ping ok. If the size is 1473, ping fail. And it is limitation.
Hope it can help you. :smileyhappy:
NETGEAR Employee
- fofwisdomDec 20, 2016Aspirant
attached another screenshot
vSphere vCenter reporting test failed.
- ElainePDec 21, 2016NETGEAR Expert
Hi fofwisdom,
If ping packet size is 1472, I capture the total packet length is 1514 by wireshark. So if ping bigger than 1472, ping will fail, due to the whole length will longer than 1514.
ping -l 1472 192.168.1.32:
NETGEAR Employee
