fofwisdom
Dec 18, 2016Aspirant
XS708Ev2: packet drop over 1473
Recntly I was bought XS708Ev2. If the size of the packet exceeds 1473, communication is not possible. Currently fimware is v1.0.0.4. I was upgraded v1.0.0.3 to v1.0.0.4 I would like to tr...
- Retired_MemberDec 21, 2016
Hi fofwisdom,
Welcome to NETGEAR community, 1514 restriction is only for ICMP packet, for other normal network traffic, Jumbo packet size (default) is 9216, DUT will drop packet larger than 9216 size.
Let's know if you see different result in further testing.
ElaineP
Dec 20, 2016NETGEAR Expert
Hi fofwisdom,
- For XS708Ev2, Switch support to reply an ICMP Echo request (PING) that is in any size smaller than 1514 bytes.
If ping packet size is 1472, I capture the total packet length is 1514 by wireshark. So if ping bigger than 1472, ping will fail, due to the whole length will longer than 1514.
ping -l 1472 192.168.1.32:
NETGEAR Employee
fofwisdom
Dec 20, 2016Aspirant
Well. ICMP isze allowed ony under 1473? Is normal network traffic green?
But I was experienced that my real network communicate dropped to simlar 10Mbps or error, in my memory. I will test again soon.
Thanks.
