aknyc
Dec 14, 2023Aspirant
Replacing a Netgear Managed GS110TP with a Netgear Unmanaged GS 308
Hi - I was trying to replace my home Apple Extreme router with an Eero Pro 6E, and was told by eero that managed switches dont work well with Eero (not really sure why).
I noticed that I have a GS110TP switch in my network.
Even though it appears that I don't use any of the managed features, I tried replacing the GS110TP with an unmanaged GS308. (keeping the router the same Apple Extreme). Weirdly, while all green link lights light up in the GS110TP, upon replacement with the GS308 only one (extreme left lit up). Any ideas what might be going on?
Thanks!
Each port with a connected device does have a Link LED (on) and activity (flashing) indication. Whatever is connected on the other ports..
https://www.downloads.netgear.com/files/GDC/GS308/GS308_Combined_EN_IG_11Jan2013.pdf
A basic GS308 does not have any loop detection or protection.
As you still have the GS110TP at hand, you could compare the results, in case you face a hardware issue on that GS308.
- aknycAspirant
Hi- Sorry I am not following you. I know what the lights mean. Why am i getting either a flashing or solid green with the GS110TP but when i swap the 110TP out and replace it with a GS308, I dont get either flashing or solid green on 7 out of the 8 ports. My question is why might this be happening.
(might it be because the 110TP has POE while the 308 does not?)
Thanks.
Any PoE powered devices connected to this GS308, not getting external power? What devices are connected? If there are no link LED indications on externally powered connected devices, I'm tempted to say the switch might be defect.
https://my.netgear.com/, select the registered switch and serial number, and head to [Request Hardware Support] or let your retailer replace the unit.
