TigerKR
Mar 11, 2018Aspirant
Router -> Bridged GS752TP & GS724TP -> LAN & Isolated WAP
Hello, I have a complex setup that I'd like assistance with. Internet <-> Gateway (Firewall, DNS, DHCP) <-> GS724TP <-|-|-|-> GS752TP <-> WAP The two switches are bridged (4 ports truncked w/...
- Mar 11, 2018Then you're set. Just plumb the VLAN all the way through both switches to the gateway.
TigerKR
Yes, I'm running the gateway services on a macos high sierra box, or rather below it on darwin - via the command line.
TheEther
Mar 11, 2018Guru
- TigerKRMar 11, 2018Aspirant
Thank you for your help. Is there a diminishing return on setting up a number of VLANs? Now I'm thinking that in addition to an isolated guest WIFI subnet, I might also put the VOIP phones on their own VLAN, the CCTV on their own VLAN, and the production equipment on their own VLAN.
- TheEtherMar 11, 2018GuruThat sounds reasonable. It really depends on how much isolation you want.
