JaritVB
Feb 08, 2022Aspirant
S3300-28X-PoE Can't add routable VLan
I have an S3300-28X-PoE. It's been working great, i have it in stacked mode with another S3300-28X-PoE and have been using it as a core switch in a small Business. (Call Center). I've been using it with Vlans and this evening when I went to add a new VLan, it allowed me to add the Vlan in the Switching Section... but when i went to the routing>Vlan Routing Wizard, and tried to complete the Vlan setup, i got an error that worries me. The error states "Error! Routing could not be setup on this Vlan. The maximum number of routing VLan's has been reached". I've only got 15 Vlans configured on here. This switch should be able to handlle up to 256 per the documentation. So, how can i get this VLan added without getting an error? Is there a place i need to, allow more Vlan's or something? I'd appreciate any and all input. I'd like to get this issue solved.
- JohnC_VNETGEAR Employee Retired
Hi JaritVB,
Welcome to our community! :)
It seems that you were having issues with creating VLAN with your switch. May I know what do you want to achieve on the new VLAN? Are you planning to create a routing on the VLAN that you created or you just wanted to assign tagged and untagged ports? You can assign ports by going to Switching > VLAN > Advanced > VLAN Membership.
Please also make sure that the switch is running on the latest firmware. If not, please do upgrade the firmware to its latest version.
John
NETGEAR Community Team
- JaritVBAspirant
Hi John,
I had created 15 previous routing Vlans with no issue.. but hit the error when trying to add the 16th routable Vlan. It appears that 15 routable VLans is the limit for this switch. Is this the case?
Data Sheet | S3300-28X, S3300-28X-PoE+, S3300-52X and S3300-52X-PoE+ p.8
Performance Specification
Number of routed VLANs 15
