FishEyeGuy
Sep 29, 2017Tutor
Set the command line banner on GS724T v4
I'm setting up a small network at my company. I've been able to do most of the setup required using the web interface. There's something I've been trying to do, that I can't figure out how to do. ...
- Oct 03, 2017
After poking around using telnet, I was able to set the command line banner. I started out in Privileged Exec mode, using enable, and then going to Global Config mode, using config.
In config mode I was able to use set clibanner to enter a double-quoted text string.
DaneA
Oct 02, 2017NETGEAR Employee Retired
Hi FishEyeGuy,
Welcome to the community! :)
I understand that you are able to have telnet access to the GS724Tv4. However, it seems that the commands you try to enter to set up a banner is not supported since there is no official documentation about it.
CLI access is supported on NETGEAR Managed Switches like the M5300 series switch models and M4300 series switch models. Configuring a banner message is a feature that can be set via CLI access. Thus, the banner message is supported on NETGEAR Managed Switches and not on NETGEAR Smart Switches like the GS724Tv4.
DaneA
NETGEAR Community Team
- FishEyeGuyOct 02, 2017Tutor
Thanks for the reply DaneA.
I kind of expected that would be the answer, but I was hoping for a workaround, given that I was able to access the switch via telnet and use several of the commands.
I'll need to get with mgmt and see how they want to proceed; either except the way things are or consider purchasing a managed switch.
- FishEyeGuyOct 03, 2017Tutor
- DaneAOct 04, 2017NETGEAR Employee Retired
Thanks for the update and sharing how you set the banner via telnet on the GS724Tv4 switch. This will help other community members as well. Kudos to you! :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
