FishEyeGuy's avatar
Sep 29, 2017
Set the command line banner on GS724T v4
I'm setting up a small network at my company.  I've been able to do most of the setup required using the web interface.  There's something I've been trying to do, that I can't figure out how to do. ...
  • FishEyeGuy's avatar
    FishEyeGuy
    Oct 03, 2017
    After poking around using telnet, I was able to set the command line banner.  I started out in Privileged Exec mode, using enable, and then going to Global Config mode, using config
    In config mode I was able to use set clibanner to enter a double-quoted text string.
ProSupport for Business
