chopkins
Jan 25, 2022Aspirant
Settings needed to create port trunking between qnap nas and Prosafe m4100-D12G managed switch
Hello, I have a Prosafe M4100-D12G managed switch that I want to set link aggregate with a qnap TS-473a NAS's two 2.5GbE ports. I tried once but the nas could no longer be reached using the browser ...
schumaku
Jan 26, 2022Guru - Experienced User
Should not be rocket science.
-> ProSAFE M4100 Managed Switch Software Administration Manual Software Version 10.0.1 - LAGs p.51 ff.
- Create LAG (one per devie, e.g the QNAP
- Add Ports LAG
- Enable LAG
- Adopt the LAG for VLAN membership
Note: For the LAG config, Static Mode indicates whether or not LACP is used, i.e. Static Mode set to Disable means
LACP is used.
Example: How to Configure LAG (applies to all switches with this Web UI)
Similar on the QTS side - select the adapter, select the LAG mode (static or LACP). This does not cause a problem, worst case disconnect one link and the connectivity will be back.
