Toruk
Jan 17, 2019Aspirant
Stack replacement works but no more administrative web access on the new switch
Hello,
We have a stack with 4 switches (GS752TXS model). One of them (unit 2) failed and we replaced it with a new one. The new switch (unit 2) is well detected by the master and works great (see b...
- Jan 18, 2019
Please try to re-stack all your switches and also make sure that you do have a back-up configuration. We might probably need to reset all the switch to factory default and stack it again. If it happens again, then it could be a firmware issue that we can raise to our engineering team.
Toruk
Hi JohnCarloV,
Thanks for your reply. Something is strange because the other switches included in the stack (no1, no3 (master), no4) can be accessed directly with their specific IP static address. So, why do we have a behavior difference between unit 1,3,4 (that can be accessed) and not the unit 2?
Thanks for your help.
Franc
JohnC_V
Jan 18, 2019NETGEAR Employee Retired
