Cerberusict's avatar
Jun 03, 2026
System name
Hallo
GS728TXPv3 with firmware: 6.2.2.40
This is a new switch and i just did the basic setup wenn i hung it in a DC.
Besecly the old switch was still in use.
Now that one is gone and i want to continue.
But i can not change the name or system contact.
The way i did: login -management.
On a other netgear switch is a purple button but not on this one.
I know normaly this is easy to do but...
On some Cisco switches it is a brouwser thingy then it log in with a Microsoft brouser and you see the compleet interface.
But never saw this on a Netgear.
Anbody know of this???
    System Name, System Location, and System Contact can be configured in the Web UI under
    •  System -> Management -> System Information
    The System Name can always be configured, independent of the Insight Management mode.
    System Location, and System Contact fields are greyed in Insight mode. There is a radio button (on/off) control, to temporarely disable Insight mode on the
    • Dashboard in the Device Details
    All the other SNMP controls - for v1/v2 as well as for v3 - are under
    • System -> Protocols -> SNMP ...
  • schumaku's avatar
    schumaku
  • Thx
    I did try what you tyot and basicly it did not work..
    I know this from other switches.
    sometimes the gui is juste to old or they can only work  with console.
    But
    Then i saw the insight button.
    I did turn this off and i could do the changes.
    Turn insight back on and i was done.
    Thx you for the help anyway
ProSupport for Business
