RockSteadyEddie's avatar
Sep 10, 2016
Unable to access internet from VLAN2 (GS105Ev2)
Set up using defaults i.e. all ports on VLAN 1, DHCP addresses picked up by clients and can access the internet (via default gateway, no problem). When I create a second VLAN (2), devices connected to (the second VLAN) appear to pick up a DHCP lease but won't connect to internet. Proabably a n00b mistake but any idea why ?
TIA!
  • Hi RockSteadyEddie,
    Welcome to the community! :)
    Kindly answer the questions below:
    a. Is your GS105Ev2 connected to a router?  If yes, what port on the GS105Ev2 is connected to the router?
    b. Is the router a VLAN-aware device?
    c. What ports are members of VLAN 1 and VLAN2?
    d. Have you double-check the PVID configuration of each port?
    Let me share the link below I found online and use it as a guide:
    Configuring a Netgear GS105E Switch with LAN/WAN ports
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi RockSteadyEddie,
    I just want to follow-up on this.
    DaneA
  • DaneA's avatar
    DaneA
    Hi RockSteadyEddie,
    DaneA
ProSupport for Business
