pealie1
Aug 25, 2015Follower
Upgrading the firmware for Prosafe XS712T
I am using SmartControlCenter to upgrade the firmare for subject switch. Which archive does one use to do so? There are 3 possible files: the downloaded zip, the mibs zip, and the stk.
Can someone please clarify? Thanks
Hi pealie1,
Use the xs712t-v6.1.0.34.stk to upgrade the Firmware of your switch.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
1 Reply
- BrianL2NETGEAR Employee Retired
Hi pealie1,
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
