bains1000's avatar
bains1000
VLAN Configuration Assistance
Hi   I am trying to setup a failry simple VLAN configuration on the GS728TPP Switch and i'm struggling to understand how the Vlan works on here.   I want Port 1 and 2 to be untagged on VLAN 10 I...
  • ElaineP's avatar
    Jun 26, 2017
    Hi bains1000,
    Welcome to NETGEAR community!
    You can configure the switch with Port 1 and 2 to be untagged on VLAN 10,  Port 3 and 4 to be untagged on VLAN 11.
    The import point is that, you need to change port pvid, after creating new vlan 10 and vlan 11, you can add port1/2 to vlan 10’s members on VLAN membership page, then change port1/2 pvid as vlan 10 on Port pvid configuration page; add port 3/4 to vlan 11’s members, then change port 3/4 pvid as vlan 11. At this moment, port 1/2/3/4 should remove from the default vlan 1.
    NETGEAR Employee
ProSupport for Business
