neverbesuccessf
Jan 14, 2018Aspirant
VLAN ID on GS105Ev2
Hi everybody I was configuring my router (edge router x) and added some VLANs on my eth1 But there he asked me about some VLAN IDs. Now I searched on my Switch (GS105Ev2) a VLAN ID which such a ...
- Jan 14, 2018
The VLAN ID as configured on the switch. For the connection to the router, you need to configure a VLAN trunk, with (typically) all VLAN are tagged on the switch. The router does need the VLAN ID to handle multiple virtual interfaces on ie. eth1.
The PVID is the VLAN untagged packets coming in in the interface are associated to.
Why create a new thread? You already started one on the VLAN config of your switch.
schumaku
Jan 14, 2018Guru - Experienced User
