E71's avatar
E71
What version of GS724T does not require JAVA?
Hi all,
Does anyone know if GS724Tv2 requires Java Runtime for its web interface?
I need a GS724T that works without Java but it seems that version 3 (GS724Tv3) onward DOES require it.
Unforunately, the online manual for GS724Tv2 appears to be a little too generic and points to the same one as GS724Tv1 as well as several other FSxxxT range switches so I can't trust that information...
Thanks,
E.
  • Hi E71,
    I believe that Java runtime is not required in accessing the web-GUI of the GS724Tv2.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi E71,
    DaneA
      • DaneA's avatar
        DaneA
        Hi E71,
        You're welcome! :)
        Feel free to post your future concerns here in the community.
        DaneA
ProSupport for Business
